Marcel Cooper
Handing house designs
When working on larger site layouts, we will hand house designs - am I alone in seeing the need for the facility to produce handed house designs from the original. hand. This was something that I used to be able to do with Microstation without effort, but when I raised the subject with Graphisoft, I was told that I was a lone voice and nobody else has wanted/needed this - are they correct?
10 Replies 10
Steve Jepson
...which is why I have not seen any reason to upgrade since v25, which is where I will probably stay as long as I am using ArchiCAD.  I expect the day is coming when the only way to use ArchiCAD will be with an online connection, and they will charge by the minuet to use the program.  I am still keeping my drafting board from 1980's just in case things come full circle in my lifetime   🙂
