Handy Layer settings Tip
I have always hated how the list of layers is too narrow and resizing the window by dragging the lower left corner just resizes the left column (layer combinations)
I discovered that you can resize the layers side of the dialog by closing the layer combo side by clicking the center arrow. Then resize the layer name column a bit wider and then turn the layer combo side back on. Viola.
__archiben
yes - and you can also do the same with the object settings dialogues too . . . should you wish to see long parameter names.
b e n f r o s t
Link
You can actually stretch it from either side, once the layer combo side is collapsed.
Link.
Rod Jurich
Link wrote:
You can actually stretch it from either side,/...
Only on the "Dark Side", Link
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
