Hatching in plan view
Zendrix
Hi!
Im new to archicad and starting to get a grip on the best mechanincs and practices.
Say we have a slab in plan view, which has a wood finish on public area and a ceramic tile finish on a bathroom: I have seen people using fills as recurrent pratice to populate the floor finish info, going around with the fill option, selecting all cornners witha  polyline and using it as an Autocad method, per say.
My question is: isnt the idea of archicad to be as effective as possible and the best way should be to have 2 different hatches already set on the slab finish properties so once you choose a plan view, its all there already done for you? I dont get the advantage of archicad if we still have to fill our floors with paralell hatches to represent a wood floor.
Thanks,
Cheers
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
Eduardo Rolon
You are correct, fills over Slabs is not the workflow.
Read in the manual about Cover Fills.
Basically you will have 2 slabs with the same Building Material and different Cover Fills (one with the one defined by BMat and the other as a Surface Override)
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
Thanks man,
Glad to hear that! 🙂
Rui
