Having trouble with the Roof Wizard
I'm having problems with the Roof Wizard. I'm trying to make a structure for my roof and when I click ok on the roof wizard it only generates a eaves perlin around the roof. I believe this is because I have a "0" Offset on my roof as when I tried it with the default "600" the full structure is generated. Does anyone know how to get this to work while using a roof with a 0 offset?
Cheers Brendan.
Maybe try it with a very small overhang value like 0.1 millimeters?
Maybe it is only the zero value it doesn't like.
Ok, I got it. Now, my problems with the Roof Wizard is done. Thank You
