Help Me!!
I want to get the ghost story to print in color.
How?
4 Replies 4
You need to change your ghost storey settings, go into the storey settings dialogue (ctrl + 7) and there should be a place to change the colour that the ghost storey appears as... you might have to click a button to enter the ghost storey settings before you have the option to change the colour, i'm not in front of a computer with ArchiCAD on it, so I cant be 100% sure, but... you should be able to figure it out from there..
HTH,
Dan
edit: just a note, the entire storey will appear as this one colour, if you need the ghost storey to be multiple colours... I'm honestly not sure how to go about doing that..
Thanks, buddy. I will try it.
Edit: It worked.
Petros Ioannou
If you want to have them both printed in colour then you can do that in Plotmaker. Very simple just import one storey on top of the other.
Don't forget to use hotspots in order to adjust their position in PM.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Petros:
That's an excellent idea, I never thought of doing that.... it may come in handy at times.
cheers,
dan
