Help calculating gross roof area
I am trying to do some energy calculations and am curious if there is any way to have ArchiCAD calculate the gross roof area for me. Is this possible?
Gerald Hoffman
Mike,
Just select all of the roof surfaces you want calculated and go to the Calculate Menu, select List Elements - Basic and it will give you the areas of all of the different surfaces of the roof. You just need to use the top surface. It should be self evident which is which.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Scott Bulmer
I am definitely not the one to speak with any clarity to calculation items in this forum (and was actually waiting to hear from them), however and since they did not respond, the easiest way I perform that analysis is to select the items then use Window>Pallets>Element Information that will return information about the selected items, including area. You have to add the areas up separately as there is no total.
I know there are many others here with better ideas.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
TomWaltz
Select the roof, then click Window > Floating Palettes > Element Info
You will see several icons along the top that are toggles to show or hide information about what you have selected.
Tom Waltz
