‎2004-05-16
12:17 PM
‎2023-05-23
05:27 PM
Rubia Torres
‎2004-05-16 09:54 PM
‎2004-05-17 06:50 PM
‎2004-05-17 10:22 PM
‎2004-05-18 07:45 AM
ICEdevil wrote:You can cut them with cutplanes (marquee) and resave as new objects, OR use SEOs to cut off the excess - no frames at the corner, though, in both cases, so that has to be faked with a roof or an extrude (see ArchiForma).
I need to create two inclined, trapezoidal, curtain walled, facades.
problem is, i can incline curtain walls, but i cannot shape them as a trapeze, in order to properly intersect in corners. i can also use the "curtain wall inclined end", but this object cannod be inclined...
‎2004-05-18 04:37 PM
ICEdevil wrote:FrameWright is very good for this type of exercise. The tools for free 3D rotation and working planes makes it quite easy to construct and edit. Take a look at
I need to create two inclined, trapezoidal, curtain walled, facades. problem is, i can incline curtain walls, but i cannot shape them as a trapeze, in order to properly intersect in corners. i can also use the "curtain wall inclined end", but this object cannod be inclined...
