‎2004-05-23
10:14 AM
‎2023-05-23
03:42 PM
Rubia Torres
‎2004-05-26 04:51 AM
‎2004-05-26 05:56 AM
‎2004-05-26 06:03 AM
Peter wrote:I agree, that is the best method and it works, however, the resulting curves are not smooth.
As I mentioned before in this thread, the glass roof pictured in
model-front.jpg and the one mentioned by squidgy_wiji
can be modeled in Archicad.
‎2004-05-26 06:38 AM
‎2004-05-26 08:59 AM
‎2004-05-26 08:19 PM
Steve wrote:Nope. Cannot use zero thickness stuff as operators for SEO.
I am to impatient for that. I was able to kind of do it with some ArchiForma help. I had to load 7.0 again because I don't have the ArchiForma upgrade yet which may make it easier. I hooked some archs together along a curve, and extruded along another set of curves. This method should allow for a good deal of precession and control since you can create an exact profile in both directions. Then sandwich a slab or mesh and use the SEO to subtract with upwards and downwards extrusions for the final roof object.
‎2004-05-26 08:25 PM
‎2004-05-26 08:38 PM
‎2004-05-26 11:05 PM
‎2004-05-26 11:29 PM
