Help with Skin priority option
New Archicad user here. What do I have to do to make the skin priority options(?) appear? As you can see from the attachment there is no drag bar for the skin priority of the composites. TIA
2 Replies 2
Erwin Edel
Priority is setup for the Building Materials that you use for a composite. So you need to change them in the Building Materials settings (if you wish to change them).
It looks like you are using an older version of ArchiCAD (at least before version 20), there might still be tutorials to be found for your version online, if Graphisoft keeps an archive of those. I would suggest having a look at those, as they take you through the most basic functions.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
In ARCHICAD 18 and later versions, when you click to select a Building Material for a skin, the Palette will display the Intersection Priority of the Building Material (in AC17 it did not). See the below image.
