fhedberg
Hidden lines under slab
Hi all,
Just installed AC23 and trying out some of the new features.
I'm having problem getting the new 'hidden lines under slab' to work.
https://helpcenter.graphisoft.com/user-guide/88282/
I have all the settings in model view to show hidden lines but nothing seems to happen.
Would anyone be able to shed some light on this...?
W11 Home | ArchiCAD 27 3001 AUS FULL
3 Replies 3
What are you seeing?
Make sure a dashed line is set for the beams hidden line type.
And if you use a 100% solid cover fill on your slab you may have to adjust the display order so it is behind the beams.
fhedberg
Thanks Barry.....
Not sure what was going on but seems to work after a reboot.
There is a clip about this new feature.
There are certain conditions that must be met for the feature to display the desired result. See it in the below clip:
