Hollow profile
Tom Krowka
I've got a roof member that I made with profiler. It is one solid polyline, but only the edges are solid. The whole interior is hollow, and you can see through it.
What am I doing wrong?
I select the object, which is one PL. Then I go to profiler, select the point to start, then give it the width value, which is actually the path of the profile. AC makes the profile, I can save, but it comes out hollow.
I am creating in the plan view.
I used curves, straight lines, which I unified into a polyline. Could this be the prob. Do I have to trace over the outline with a "virgin" polyline?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Replace polyline with fills
Ben Odonnell
Or you can just close off the polygon of your profile.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Get your BIM objects from bimobject.com
