2022-03-08 04:56 PM
OK trying to narrow this down to a narrow solution
I have multiple use for horizontal and vertical ribbed, corrugated and smooth panels
The smooth is east. Just a material though it does not include the skin thickness
A horizontal I can create in the Wall assembly
Little time consuming but the sections are even better than the Wall assembly as I end out with a metal skin on hte entire panel. And also some of the flashing
It is the vertical panels I have issue with. I want to keep them walls so that I can place doors and windows with ease.
And overall I’d prefer one solution that would allow me to rotate the material. And result in a good section.
2022-03-08 05:11 PM
My free coverings will likely do what you need. you can also use custom profiles in the coverings if the basics ive included arent whats needed.
link in my signature.
2022-03-09 02:30 AM - edited 2022-03-09 02:45 AM
There was also Hmooslechner's accessory.
Also, which version did you code in Seneca?
2022-03-09 03:00 AM
Currently v24
