You want to enable the Marker within the Door / Window Settings dialog. The choice of markers / appearance and the default behavior will vary based on the localized version of ArchiCAD. The screenshot shows the USA version; the RUS or INT versions will be slightly different. (The markers are library objects and part of your localized library.)
For plans, this is no doubt what you want. But, you can also use the associative label tool to define labels for doors/windows ... and those labels can be made to appear in section/elevation as well (but without the dimension information available with a Marker).
PS Please post future screenshots / images as attachments to your posts, rather than as URLs to external sites. The forum spam filter may delay your post if you use URLs.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
