ā2010-02-15 03:39 PM
ā2010-02-22 07:12 PM
ā2010-02-22 07:17 PM
ā2010-02-22 07:20 PM
ā2010-02-22 07:43 PM
ā2010-02-22 09:21 PM
ā2010-02-22 10:49 PM
David wrote:I'm not entirely sure about this but from what I understand MEP 12 doesn't run once MEP 13 is installed. The workaround is to work in 13 and save back to 12. AC12 (without the MEP add-on) can open the file properly with the MEP12 library loaded. You just can't edit the parts like you can with the tools loaded.
BTW - I still can't get my MEP Modeler Add-On working (ever since Hotfix#5, my MEP for AC12 has been broken). At least AC13 is working fine.
ā2010-02-22 11:11 PM
ā2010-02-22 11:22 PM
Karl wrote:MEP is also working fine in 12 & 13 both platforms.
MEP works in both 12 and 13 for me. I believe the deal is that the add-on has to be installed so that the hotfix updates it properly. Otherwise, presumably the current download of the add-on will work.
ā2010-02-23 01:30 AM
