Hotlink Surfaces
drh64
I have walls linked to a larger model with composites for the materials/surfaces. I cannot get the correct material to show in the master model as they are in the hotlink. The siding material will not show and it is greyed out. What am I missing here???
8 REPLIES 8
David Maudlin
Daniel:
I don't know how the Hotlink might affect this, but in your screen shot the Outside Face Surface button is not active, so ArchiCAD is using the Surface (old Material) assigned under Building Materials for that side of the wall. If you activate the Outside Face Surface button then you should be able to Override Surface to assign any Surface (old Material) to that side of the wall.
HTH,
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
"Outside Face Surface button is not active,"
I was not aware of being able to deactivate one of the 3 choices.
How does that happen?
David Maudlin
3d4draww:
As you can see in Daniel's screen shot (Model panel), the 2nd and 3rd Override Surface buttons are depressed, so a custom Surface (old Material) can be assigned. The 1st button is not, so the wall is using the Surface assigned to the Wall's Building Material (new attribute), which is the exterior Building Material of the Wall's Composite Structure. It will take some time for users to understand the use and consequences of this new attribute.
Ahhh,
Must be a 17 thing?, which I've not loaded yet.
David Maudlin
3d4draww wrote:
Must be a 17 thing?
Yes.
drh64
Thanks David. I'm getting the hang of this now. All of the material and surfaces is a lot different to get accustomed to but well worth it...!
David Maudlin
Yes, it took some time to get my head around the new concept, but now I wouldn't want to go back.
It is funny, that there is no new materials/surfaces and archicad is using total nonsence surfaces for building materials...
