caitlinkelley
Hotlink issue! Roof trimming lost
I'm working on a model that has several buildings and I'm bringing some buildings in on a floor by floor basis because they don't match the host file's story settings. I'm getting the correct floor heights now but the walls that have been trimmed to roof in the original file are not staying trimmed when I bring them in as a hotlink. Does anyone know how to fix this? Thanks!
Caitlin Kelley Architect
AC24
MacOS Catalina 10.15.7
2.4 GHz 8 Core Intel Core i9
64 GB Memory
AMD Radeon Pro 5600M 8GB
SEO's between different stories will not be maintained when the stories are brought in individually. In the hot linked file try using "Trim elements to roof or shell" from the connect menu, which should be a permanent trim, but will not update if you move the roof (operator).
caitlinkelley
Thank you. I'll give that a try. I appreciate your suggestion.
AC24
64 GB Memory
