Hotlinked module - rotation - (cover) fill orientation problem
rakurs
Hello, everyone, from beginners to experts!
I have a project in which I've managed to use hotlinked modules for the first time. The hotlinked modules are modelled orthogonally, and then placed in a main file where they are rotated. How do I fix the rotation of (cover) fills? Is there a way for ArchiCAD to treat hotlink's origin and its rotation as origin for its fills, and not the main file's origin? I know I can probably manually edit every slab's fill and set its fill's origin and rotation, but I don't know how (or if) I can do it for the cut walls.
Ideally, it would be a switch somewhere - rotate all the hotlink's fills according to hotlink's rotation and position, but I can't seem to find it if it exists.
Thanks in advance!
Operating system used: Windows W10Pro 22H2
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
4 REPLIES 4
BrunoH
Hi Rakurs,
For your walls go to Material Attribute Manager and change the fill origine of it's Material to "Element origine" (see atta
ch).
ArchiCad 3.43 to 28
MacOS Monterey
Lingwisyer
Guru
Yeah, having to set the Cover Fill Orientation for every coverfill used in a Hotlink adds a fair number of clicks. Might be worth a Wish.
AC22-28 AUS 3001Help Those Help You - Add a Signature
While that would be helpful in some situations, it would also mess up many other views, and would add inconsistency to the way walls are represented, or, at least, how I would like them to be represented in my drawings. For example, complex profiles need the setting to be "project origin" to behave correctly in sections. Adding a bunch of materials for the purpose of showing them as wished is clunky and really not feasible, as it would mess up other things and raise the possibility of making display (and other) errors which are tough to diagnose.
I have done just that. Thanks for the suggestion.
Setup info provided by author
