Dave Brach
view orientation vs. model rotation
I usually orient the building so that north is up on the screen, but sometimes to fit the building on the layout I want north to be facing left on the screen.  Is there a difference between changing the view orientation to 90° vs. selecting the entire model and rotating it 90°?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
ryejuan
It is better to use view orientation than rotating the model to prevent unnecessary adjustments with your textures, fills etc. basically you'll just save a new view with the rotated view orientation then re-link it back to your layout. 😁
WINDOWS 11 PRO
DGSketcher
Legend
I try to avoid rotated views in my View Map, better to set up an Ortho view that suits your presentation. I seem to have trouble in rotated views with elements rotating unexpectedly or not rotating when needed. For output I do rotate the drawings on the Layout to fit the sheet where necessary, for PDF or Paper this isn't a big issue, but more of a thing on BIMx.
