‎2005-02-08 07:22 PM
‎2005-02-09 04:02 PM
How would I place a coordinate on a point or multiple points like in Autocad C&GI am not sure what you are asking and have never used any version of Autocad. If you explain what you are trying to do, perhaps there is a solution. I also do not use Artlantis.
‎2005-02-09 06:01 PM
another Moderator
‎2005-02-09 06:31 PM
ejrolon wrote:... and you have to be in a perspective view. Even if you don't see s***, it will export.
TO export to Artlantis... In AC go to the 3D window -> choose save as -> in the options select Artlantis...
that is as simple as it gets
‎2005-02-09 08:05 PM
Mark wrote:I have found ArchiCAD to be consistently correct in the NSEW department. What is often lacking is any indication from the surveyor which direction the measurements are taken. After putting in the metes and bounds, I just check to see if the project north matches the survey (otherwise it will be pointing due south).
ArchiCAD tends to do 'Southing and Westing' when you put in surveyor's coordinates...I always double check and if necessary reverse or draw in the reverse (minus) direction. This topic has appeared several times since joining an earlier version of this forum in '99.
‎2005-02-09 08:21 PM
