‎2010-04-25
08:50 AM
‎2023-05-23
04:50 PM
Rubia Torres
‎2010-04-25 11:22 AM
peter_h wrote:It is possible to create snappable edges on a GDL object. The trick is deciding where to put them. It's quite simple for the simplest shapes, e.g. rectilinear blocks, but the number of edges in a 3D body becomes enormous when curves are introduced, and particularly if the shapes is cut/rotated/bent.
Is it an AC shortfall, or some switch that add-on/GDL programmers need to turn on when they create their objects?
‎2010-04-26 01:25 AM
Ralph wrote:Ralph: Just out of interest...do you mean that it could bog down the CPU, or be a problem with isolating the point you want to select when surrounded by too many snap-points? I assume you mean the latter, as the CPU has no problem with all lines being "hot" in section/elevation.
the object could easily become a nuisance
‎2010-04-26 03:33 PM
peter_h wrote:Primarily the latter. A dense cloud of snap points can be a real pain to work around, especially when dimensioning. The former is also potentially an issue, but at the point where the object view is generated (refer to the next comment).
peter_h wrote:Section views can take quite a while to generate (depending on size) because ArchiCAD has to generate a 3D body and then produce a hidden line view from it. If it did the same in plan, there could be a significant performance penalty. I believe this is why SEOs are not shown correctly in the plan view.
Why on earth is this super-productive ability crippled in plan-view - the most oft-used and useful view of all?
peter_h wrote:Thanks! Your feedback is much appreciated.
As for my 2cents with your future Objective improvements, relating to this issue...
‎2010-04-26 03:49 PM
Section views can take quite a while to generate (depending on size) because ArchiCAD has to generate a 3D body and then produce a hidden line view from it. If it did the same in plan, there could be a significant performance penalty. I believe this is why SEOs are not shown correctly in the plan view.hmm...so im curious...how GS team can make SEO working in plan ? Do you Ralph have any idea cos you are familiar with these limitations of archicad and programing...i m wondering cos this is very needed option in archicad ?
‎2010-04-26 04:10 PM
NeckoFromSarajevo wrote:I'm sure they've already done it for testing purposes and decided the performance penalty was too great. SEOs in ArchiCAD are not like the static boolean operations provided by many other 3D modellers. In those instances, the geometry created by the operation is persistent, so the overhead in displaying it in any view is quite light. ArchiCAD dynamically generates the geometry on demand, which can be very slow for some SEOs. We generally accept the delay in building a section/elevation or 3D view, but I'm not sure anyone would be pleased if the plan view took the same hit.
‎2010-04-27 12:04 AM
‎2010-04-27 03:52 AM
‎2010-04-27 05:42 AM
peter_h wrote:Have you tried using guide lines instead of actual lines.
(Without tracing the object with temporary lines, from corner hotspot to corner hotspot)
‎2010-04-27 03:40 PM
