How can I save the shortcuts scheme?
Is that possible? How to do that?
NCornia
Graphisoft Alumni
Graphisoft Alumni
Mlegs,
Go to Options>Work Environment>Work Environment. In the Work Environment dialog go to Keyboard Shortcuts to edit the shortcuts then go to Shortcut Schemes, select the Custom listing on the right and then click "Store As..." to store the scheme.
Once it is named, select it from the list of schemes and then click "Export" if you wish to store it in a specific folder for future import or to share with others.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Oh thank you but it seems im too stupid to make it . I went to work environment - shortcuts scheme - store scheme stored my scheme after i set my shortcuts how i liked. but after a fight with importing the scheme, i finaly did it after 2 crashes of archicad. However, I applied the scheme i have saved and it seems anything gone default So i will have to do set all my shortcuts all over again ?
NCornia
Graphisoft Alumni
Graphisoft Alumni
Unfortunately yes. If the scheme was not properly exported and a crash occurred you will have to re-create the shortcut scheme.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
