How can I set the line type of slab on the floor below?
Andro Architect
Hi everyone !
Simple question, how to set the line type of slab that is displayed on the floor below?
It should be simple but in Dialog Settings of slab it is not possible to select the type of line on the floor below.
2 ACCEPTED SOLUTIONS
Andro Architect
OK I found It. Option>> Project Preferences>>Legacy .
P.S. I don't understand why there? and why it was not possible to give in Dialog Settings? The user has to get tired.
Eduardo Rolon
Under Archicad Preferences -> Legacy.
ā€ƒ
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
6 REPLIES 6
Andro Architect
Eduardo Rolon
ā€ƒ
AC28 US/INT -> AC08
another Moderator
Thanks Eduardo
I just found it before a moment and was surprised.
It is a Legacy option so it is there because sometime between 1984-2010 it was the easiest place to control, probably before MVOs were introduced.
AC28 US/INT -> AC08
another Moderator
Exectly, and it's sad, because the user has to check in Dialog Settings, then MVO, then in Work Environment just in case, and only then has to guess that it can be in Project Preferences.
I still hear that Archicad is intuitive šŸ˜€
