How do I Save Custom Door and Window Marker?
shir_khann
Hi Everyone,
I am trying to figure out how and where to save the custom markers that I have made for my doors and window so that I can import them into my future projects and template. I see the option "load other window-door marker..." and would be great if anyone can help and explain how to save this custom markers and reload them into future projects as it will save me a lot of time.
I found this post which is way back from 2005 and doesn't help very much with the current version.
https://community.graphisoft.com/t5/Modeling/Door-Window-Marker/m-p/38259/thread-id/19006
undefinedundefined
AC26 AUS | AMD Ryzen 7 3700X 8-Core Processor, NVIDIA GeForce RTX 2080 SUPER
12 REPLIES 12
Hi!
I understood your answer, but I can not find door mark in Archicad library anywhere.
Is it possible that it is not awailable from Archicad 26 on anymore?
I clicked through all 2D symbols in Archicad and could nto find it ...
I wonder now how could I change Archciad default door stamp, so it would change in all doors at once.
Yves
This type of object is not visible in the object tool
You have to go to the libraries and objects menu
Here are screenshots from the French version
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thank you soo much!
I finally found it!
