How do I change the face brickwork hatch pattern color from black to red ?
mthd
Ace
Hi, how do I change the face brickwork hatch pattern color from black to red ?
I am using a pre set element attribute from the list. Is this a vectorial fill that cannot be edited ?
I have edited the composite for the wall lines but there is no option in that dialogue to change the fill hatching pen color ?
Can anyone show me how to go about it ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
2 ACCEPTED SOLUTIONS
You should have a Building Material set up for your brickwork.
You can change the fill pattern and colours in the Building Material settings.
I am assuming you mean the fill in plan/section.
If you mean an associated hatch you see in elevation then see AllanP's post below.
AllanP
For the pen on the elevation, its built into the surface that is assigned to the building material.
Attributes -> surfaces
select your brick surface..
the pen to the right of the Vectorial Hatching fill pattern.
change from element pen to a selected pen.
i hope this helps,
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
4 REPLIES 4
AllanP
i hope this helps,
Thank you very much for the help Barry.
mthd
Ace
Thank you, it helped allot and both of you helped me navigate the newer versions of Archicad.
It’s easy to get lost in the dialogue boxes with re setting pen colours and weights ?
