ā2008-11-17
08:45 PM
ā2023-05-23
04:58 PM
Rubia Torres
ā2008-11-17 08:50 PM
ā2008-11-17 08:53 PM
ā2008-11-17 09:13 PM
ā2008-11-17 09:19 PM
rhendrickson wrote:
I tried the Find and Select and limited it to the layer I want to delete. Nothing happened. Do I have to do that in each detail or drawing in the project?
rhendrickson wrote:The "all visible and unlocked" layer combination can be misleading, since it appears that you are trying to locate an element on a non-standard layer. Open the layer dialog and check that all layers are indeed on and unlocked.
I was in the main floor plan in the "all visible and unlocked" layer combination.
ā2008-11-17 09:39 PM
ā2008-11-17 09:42 PM
rhendrickson wrote:Yes it is -- this is why, if it's so hard to track down, I just delete the layer anyhow -- a single missing element is usually not worth the effort to comb thru 100+ drawings -- if it's anything important, you will stumble upon it eventually (although I have yet to find anything missing).
It is a slow process to go through 100 plus drawings to find a line that needs moved to another layer.
ā2008-11-17 11:03 PM
rhendrickson wrote:Only if the element in question is a 2D element or object. If it is 3D, then just open the 3D window and use F&S there.
I tried the Find and Select and limited it to the layer I want to delete. Nothing happened. Do I have to do that in each detail or drawing in the project? I was in the main floor plan in the "all visible and unlocked" layer combination.
ā2008-11-18 12:10 AM
ā2008-11-18 01:10 AM
