How do I find an object in a particular layer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-11-17 08:45 PM - last edited on 2023-05-23 04:58 PM by Rubia Torres
Any suggestions?
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 08:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 08:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 09:13 PM
The mod files have had the link broken, so they are part of the project.
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 09:19 PM
rhendrickson wrote:
I tried the Find and Select and limited it to the layer I want to delete. Nothing happened. Do I have to do that in each detail or drawing in the project?
Yes
rhendrickson wrote:The "all visible and unlocked" layer combination can be misleading, since it appears that you are trying to locate an element on a non-standard layer. Open the layer dialog and check that all layers are indeed on and unlocked.
I was in the main floor plan in the "all visible and unlocked" layer combination.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 09:39 PM
Thanks.
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 09:42 PM
rhendrickson wrote:Yes it is -- this is why, if it's so hard to track down, I just delete the layer anyhow -- a single missing element is usually not worth the effort to comb thru 100+ drawings -- if it's anything important, you will stumble upon it eventually (although I have yet to find anything missing).
It is a slow process to go through 100 plus drawings to find a line that needs moved to another layer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-17 11:03 PM
rhendrickson wrote:Only if the element in question is a 2D element or object. If it is 3D, then just open the 3D window and use F&S there.
I tried the Find and Select and limited it to the layer I want to delete. Nothing happened. Do I have to do that in each detail or drawing in the project? I was in the main floor plan in the "all visible and unlocked" layer combination.
It would be nice if there was a way to search for 2D content across all viewpoints...
One of the forum moderators
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-18 12:10 AM
Thank you for your time and for your help!
Roger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-18 01:10 AM
Link.
