How do i convert a 1:250 drawing to be 1:1 in 3D?
Is that possible or do i have to redraw the drawing with the correct measurements?
2 Replies 2
Are you using Archicad 10 ?
Do you want to produce an independent drawing? In that case you should save the view and publish it.
Do you want to meke 3D measurements?
Jaime Neto
Archicad 10.00-C2083-POR-Full | Apple MacBookPro 17'', 2GB Ram
Djordje
What you do in Archicad is always 1:1. The plan, section and elevations are shown in scale - but the sizes you input are always true sizes. Therefore, your model is always in real size. Just make sure that you use proper units - e.g. if millimeters, then for one meter use 1000 ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
