How do i create 3d text?
hey guys, how do i create 3d text for instance to create a sign, i looked on another topic and it suggested in the library there was 3d text but i can't find it anywhere????
daryan
4 Replies 4
Eduardo Rolon
Archicad Reference Manual page 225,
under "Locating a Library Part"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
What happens if you use 'Find Library Parts' in the object settings dialog? Search for 'Text' e.g.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
David Maudlin
daryan:
In the Object Settings dialog box, in the upper left pane select Find library parts and search for "Text 3D". You should have the ArchiCAD Library loaded.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thanks very much found it
