‎2005-09-20 07:55 AM
‎2005-09-20 04:09 PM
It would be so simple if you could use "Align 3D Texture: Set origin" in the Elevation view.I agree mate, it is considered a 3D view as far as transparency is concerned, so why not the 3D Texture? Anyway, you should be able to set the 3D Hatch origin in the 3D window, and then go to your section and relocate the fill handle to the same point (especially if that point is on a corner node of the wall).
‎2005-09-21 01:07 AM
‎2005-09-21 01:32 AM
‎2005-09-21 01:39 AM
