How do you align a patch fill with a wall material????
Stress Co_
I'm trying to use a "Fill" as a patch over a wall on an elevation view of my model. The wall has a material - hatch (stone).
I can't seam to get the patch-fill to align with the the wall materials "vectorial hatching". Their the same "fill type".
It would be so simple if you could use "Align 3D Texture: Set origin" in the Elevation view.
Know any work arounds???
Thanks
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
4 REPLIES 4
Link
I agree mate, it is considered a 3D view as far as transparency is concerned, so why not the 3D Texture? Anyway, you should be able to set the 3D Hatch origin in the 3D window, and then go to your section and relocate the fill handle to the same point (especially if that point is on a corner node of the wall).
See you soon.
Link.
Stress Co_
Thanks Link:
I tried that........but it didn't work. Until.......
After much frustration.... I figured out that the fill/vectorial hatch applied to the wall's "material" was a mirror image of the patch fill. Kindawierd as they both use the same "fill" (stone pattern).
Maybe we'll be able to set origins in Elevation windows in AC X ??
Aloha is it?,
Marc
Link
Try drawing your wall in the other direction mate!
Use 'Clean Beam & Wall Intersections' to check the direction.
Aloha in 3 weeks!! I'll catch a few waves for you!
Link.
Stress Co_
@#$%^, I created a new "reverse" fill. I should have guessed.
My offer still stands.... just fly me over and I'll be your board caddie
Marc
