Generally speaking, I do not model any interior trim.
I don't model plaster finishes either, as I don't dimension to the plaster finish.
All the linework from trim clutters up my sections. Lots of lines close together might look fine when looking at them as hairline thickness on screen, but they print out as one thick black mass.
I have, on rare occasions, modelled fancy trim, but only for interior rendering purpose. I generally hotlink my 'technical' model to a presentation pln where I can just freely add a ton of objects, etc to make things look good for the render, I just don't want this stuff cluttering up my technical drawings.
Like Barry, I have my 1:5 scale details to show excactly how things should look.
If I do find it essential to show some trim on my 1:50 drawings I either use the standard casing to mock this up or I just make a simple upside down U shaped complex profile that I can easily stretch around the windows. This last method works on small residential projects, I would not bother with that on big projects.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
