How do you extrude a shape along a path?
Festim Idrizi
I have a very difficult railing that I want to shape, I can do that in 3ds max but not in Archicad because the angle doesn't get correct, is there any way how I can use the Morph to do it?
Thanks,
Festim
4 REPLIES 4
snow
´Hi there,
Have you looked at this in the help file?
You've to follow the path manually...
You mentioned railing, so have you tried the Railing tool? You can create complex profiles in the shape you want that will follow the path of the railing.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Hmooslechner
There exist some axamples with GDL-Objects:
https://bimcomponents.com/GSM/Details/25723
https://bimcomponents.com/GSM/Details/25722
https://bimcomponents.com/GSM/Details/23828
https://bimcomponents.com/GSM/Details/24250
https://bimcomponents.com/GSM/Details/24075
https://bimcomponents.com/GSM/Details/24632
Always look at the description-Text - there are Youtube-Tut-links in there.
Another way - morph-face can follow an 3D-Morph-path with curves:
Setup info provided by author
