How i can make the door is double rather than single door ?
Hi, when i downloaded from depository, i found there is option to make it single door or double door can the same applied for any single door inside its setting
and if it's possible can anyone guide me how ?
Thanks
In the Door Selection Settings "inject" (atl-control-click) these settings into the D2 15 door in the Wood Internal Doors folder.
It should retain your door panel and casing settings etc. but with the double-door library part.
AC15 has a much better range of external doors than AC14 with some double doors (see image), but why no basic double entrance door?
It seems a fairly obvious gap in the library. It would matter less if you were able to switch off the sidelights of the available double doors, but I don't think you can.
If GS prefer to produce a library of similar parts rather than a single fully parametric part, that library should strive to be complete.
