2018-12-04 09:09 AM
2018-12-07 11:09 AM - edited 2022-12-19 09:37 PM
You can find their description here:
https://help.graphisoft.com/AC/26/INT/index.htm#t=_AC26_Help%2F060_ElementParameters%2F060_ElementPa...
It is towards the end of the table.
Related Zone Name - 2D
Name of the element's related Zone, if any.
In general: the Zone which the element borders or intersects in 2D.
Related Zone definitions vary by element. See Description.
An element can have only one Related Zone. (If multiple Zones apply, the first create Zone is listed.)
(To identify the Zone(s) with which an element intersects in 3D, use the “Related Zones- 3D” parameter.)
Wall: The Zone which it borders, or the Zone which the Wall's 2D polygon intersects
Door/Window: Related Zone of the host Wall.
CW: The Zone which it (or at least one of its segments) borders
CW Frame/Panel: The Zone which its CW segment borders, and which the Frame/Panel touches.
CW Junction: All of the connecting subelements (at the Junction's gridpoint) border the Zone; or two of the connecting Frames (at the Junction's gridpoint) border the Zone
CW Accessory: The Zone bordered by the Accessory's parent Frame.
Shell/Roof: The Zone to which it connects via SEO, or by which it is cropped
Object, Light, Morph, Stair, Railing: The Zone that has the same Home Story as the element. For an Object: the centerpoint of its 3D bounding box is within the Zone polygon.
Beam: The Zone which the Beam's Reference line intersects in 2D. The Beam must be visible on this related Zone's home story.
Skylight: The Zone to which its parent Roof or Shell connects via SEO, or by which it is cropped.
Column: The Zone polygon intersected by any corner of the Column. The Column must be visible on this related Zone's home story.
Tread, Riser, Stair Structure: The related Zone of its parent Stair
Railing subelements: The related Zone of its parent Railing
Related Zone Number - 2D
Number of the element's related Zone in 2D, if any. See explanation for Related Zone Name - 2D, above.
Related Zone Name - 3D
Name of the Zone which the element intersects or borders in 3D, if any.
Related Zone Number - 3D
Number of the element's related Zone in 3D, if any.
2019-02-15 07:17 PM
