LeeJaeYoung
How should I handle this warning message?
AC27 on window 11
4 Replies 4
Use Find & Select to find those elements with IDs... SW - 324, SW - 325, etc.
Once you have found them, they may have bad geometry that you can correct.
Or delete and replace them.
It is hard to say what the actual problem is without seeing what they are.
Barry
LeeJaeYoung
감사합니다^^
thank you
AC27 on window 11
Lingwisyer
Guru
Remember, this is a community forum, so people may not always see your questions straight way, or that may not have an answer or path of query. Some questions may go unanswered for several days. Once it gets to that point, you can always "bump" your post. Remember to update your post if you have troubleshooted new things in that time, or on the odd occasion even found a solution.
Ling.
LeeJaeYoung
Yes. I know ^^
AC27 on window 11
