2005-02-17
08:35 PM
2023-05-26
12:43 PM
Rubia Torres
2005-02-17 11:46 PM
2005-02-18 12:47 AM
Link wrote:I was hoping this is not the only solution. I would have liked to connect from bottom of a column to the top of another column in 3D. I tried using BEAMS objects in the library but AC9 crashes?! Any other approach, hopefully in 3D?
TrussMaker springs to mind. It's in your Extras menu.
Link.
2005-02-18 04:04 AM
2005-02-18 09:06 AM
2005-02-18 06:05 PM
Djordje wrote:Please help, still crashing!
Joseph,
I use the standard lib parts daily, for all the steel (and ALL the stuff I am doing last year and more IS steel!) structure. Works like a charm.
Beware of the hotspots - you have to catch the correct one for the action required.
As ben said, if you are crashing, there has to be something else!
HTH,
2005-02-19 02:57 AM
Joseph wrote:try narrowing it down a little:
I go to 3D window in Open GL mode. I open the Object tools pointing to Steel Beams 9, as soon as I click ok AC9 crashes and a Bug report is sent to GS!!
2005-02-20 08:07 PM
~/archiben wrote:Thanks and I tried the following:
does it crash when you're using the internal engine rather than openGL?
do other objects work when in the 3D openGL window?
and most importantly: have you contacted tech support with your bug numbers and had them get onto it quick smart?![]()
cheers
~/archiben
2005-02-20 08:20 PM
Djordje wrote:Djordje,
Joseph,
HTH,
2005-02-21 12:49 AM
Joseph wrote:you have to do it in two hits: the hotspot in the centre of the beam is the angle rotation and the one in the middle at the end will allow you to stretch it . . .
I do not understand the charm that one has to figure out the "Angle" between a column and a brace manually to input in settings instead of simply garbing the end of the brace an attaching the brace from bottom end of one column to top of the next column, or am I missing a vital HotSpot?
