‎2025-11-12 09:57 AM - last edited on ‎2025-11-12 12:17 PM by Barry Kelly
I would like to make Story 0 (Lobby) the reference level for my dimension levels, so that the Lobby level becomes +0.05 instead of +1.05. How can I adjust the reference level so that the elevation dimension starts from Story 0?
Operating system used: Windows 10
Solved! Go to Solution.
‎2025-11-12 10:12 AM - edited ‎2025-11-12 10:13 AM
You can set a seperate custom reference level in Options > Project Preferences > Reference Levels. Offset that by the 1 meter needed and you can set your level dimensions to use the custom level instead in the Text Content either as single value or as a custom text.
‎2025-11-12 12:20 PM
Or set storey zero to 0 instead of 1000,
But that is probably a bit late now as you would have to adjust all of the other storeys and then move any annotation you have added to sections and elevations.
Probably best to use a reference level as Erwin suggests.
‎2025-11-12 02:29 PM
I think project zero (and story 0) is being used as some sort of real world level dimension and it's probably a pain in the behind to change it now.
We use a reference level for the real world level dimension, since this is generally a flexible level throughout the span of a project.
‎2025-11-16 05:10 AM
I have another problem
When I move the slab down by 5 cm, the level dimension doesn’t update automatically it still shows +0.00 instead of -0.05. How can I make the level dimension automatically update to reflect the new slab elevation?
‎2025-11-17 01:49 AM
You did use the 'Level Dimension Tool'?
If so make sure it is not set as 'Static' or custom text.
It will associate to and adjust with the slab.
