Brad wrote:
Does anyone know of a way to save plans or elevations to high resolution format that can be used in photoshop?
Use PDF. (EPS is a similar option.)
A nice thing about PDF is that with 8.1 with print-marquee, you can create a PDF of just the part that you want. When you open the PDF in Photoshop, you're asked how big of an image you want. Don't be bashful if you need high res. I just made a test with a small piece of drawing at 3,000 pixels wide - looks great.
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.8, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
