How to create Difference Wall pattern in Plan and Section.
Inglewood78
This is possible or not to Create a Pattern wall in plan difference with section.
Refer to image 1(wall plan)  is use diagonal. And Section i would like to change pattern to Horizontal double line.
Thank you so much for suggestion.
CosminF
You can achieve your desired representation by using graphic overrides. Basically, you tell Archicad to replace, in sections or any desired views, all the wall cut fills with a different cut fill. You can have different fill colors etc.
More on that here: https://help.graphisoft.com/AC/24/int/_AC24_Help/050_ViewsVB/050_ViewsVB-134.htm
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
4 REPLIES 4
CosminF
Thank you so much.
But keep in mind that Graphic Overrides always affect the whole element. In case of Composite Structures and Complex Profiles, that can lead to unexpected results, like your example where all three skins of the Composite will be overridden with the spacified fill.
This is also a problem that GS should have solved a long time ago.
Resources shouldn't be wasted on beautifying kitchen cabinet handles, but on important things like this...
Gábor
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
Setup info provided by author
