2011-01-07 07:48 AM
2011-01-07 07:58 PM
Deviz wrote:You can cut a freeform detail or worksheet but then you have to do the annotations in the detail/worksheet window so it's no longer a live model view.
It's really dumb that ArchiCAD doesn't simply allows to cut a free-form detail marker, which makes everything else around disappearing and leaves the live model to be documented.
I wonder what system does Revit have for this!!!Revit has the advantage here (to a point). You can create as many levels as you like with the extents individually set. In other words, plan views are pretty much like horizontal sections. Unfortunately the method is not intuitive and from what I've seen most users don't know how to use it very well. As I recall the extents are strictly rectangular. Managing overlapping enlarged plan views still has its share of complications.
