SOLVED!
How to create and use corugated insulated metal panels
Eric Milberger
How would you guys d this?
I have a CMU wall that will have an corrugated-insulated Panel installed on a CMU WALL.
the corrugated panels are created from a BEAM
I create the wall with a CMU wall that has rigid insulation as a part of its compound wall type an then another metal panel
I will place flashing on the corners
The section looks great but here is where I fail.
  • The top of he wall needs to slope - how to do this
  • I need to cut holes in the metal panels and cannot find out how to do that
  • I would like this to be a single wall so that it change size easily from project to project.
I wish this was a solid wall type so that doors and windows - opening as the such would work.
ADVICE IS APPRECIATED
Operating system used: Windows 28
Eric Milberger, Architect | Master Planner
10 REPLIES 10
I did but for this wall there is on ly the single material and I believe I can do this with a surface
Setup info provided by author
