How to create one story building from many stories?
Mats_Knutsson
Mentor
I have a multistory building which I'd like to change to a one story building. I need to change home story but the elemenst reposition themsevles and I need to manually keep track and check everything which will take me all day. Is there a smarter way to change the home story to one single story for all elements on all floors?
Mats
AC 25 SWE Full
Erwin Edel
Insert your .pln as modules on one story in to a new project, reposition the modules and then break them.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
You can do it one element type at a time - i.e. select all walls then all slabs, etc.
Then just click on the 'Home storey' in the info box and choose 'Select Storey" and chose the storey you want the elements t be on.
They should retain their relative height in in 3D and appear unmoved.
This was in 16 - it is different in 17 though.
You must use the 'Relink Home Storey' command (Edit menu > Element Settings > Relink Home Storey).
Mats_Knutsson
Mentor
Thanks a million!
I used Barrys advice and now I can go to bed.
AC 25 SWE Full
