How to delete/replace added to favorites?
I found myself repeating saving adding to favorites.
As I can not replace the existing, I have to use other save name.
Is there a way to delete or replace the existing one?
Erwin Edel
Window > palettes > favorites
This shows you your saved favorites and allows you delete them or redefine with current settings. You can preview the settings in the info box, change them and then redefine.
These options are listen under arrow button on the topright of the palet.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks.
