How to draw a wall
hi, newish user of archicad, use mainly autocad..
anyhow, please could anyone tell me of how to draw a wall wich say starts at 1m high and then gradually inclines to 3m over the distance of say 6m?
i basicly want a wall that starts lower and inclines, have tried to find a way but i have a deadline coming up and so running out of time to find out for myself!!
please help!?
39 Replies 39
the wall returns as before, i thought it may have worked as you suggest, like trim on autocad, but rater than staying trimmed the wall pops back! 😞
i will create you a little tutorial with complex profiles !
whait a few minutes
thank you very much, this will be alot of help!
Sounds like you have used the Solid Element Operation to trim the wall, rather than the less used "Trim to roof" command. Trim to Roof is permanent. SEO adjusts as you move (or delete) the operator.
1 step
2 step
3 step
4 step
5 step
6 step
