How to edit a objects - Dormer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-08-10
12:57 AM
‎2023-05-23
04:53 PM
Rubia Torres
As a beginner i have some problem to edit the dormer. My plan is to have a dormer with three windows but I´m not able to edit the dormer in Archicad. I´m not able to choose more than one window. How do I edit this object or do I have to built a whole new dormer? How do I built a new dormer if I have to?
Best regards
Henrik
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 06:44 PM
What rendering engine (or settings in 3D window) did you use to make that image? It's fantastic.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 07:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 07:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:03 PM
I tried to do as Peter said but I didn succed. I succeded with the roof on the dormer but not inside the house. I attach a 3D view from inside that show my problem. As you can see I would like to cut the wall with the same angle as the roof inside. I not sure I´m understanding how I´m going to do. What do you mean with "command klick"?
/Henrik
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:14 PM
JaredBanks wrote:hummm??? I didn't actually switch any lines? The black for the siding, or the roofing comes from the material settings. But, maybe you are on to something else
Learn something everyday. I never thought to switch the pens to black and white before going to 3D. !
I always liked the Internal Engine, even though most here seems to go via Artlantis.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:16 PM
command + click on macs: if, in 3d, you select a wall, then hold down the command key and click on the roof, the wall will trim to the roof.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:18 PM
I'll try again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:19 PM
Okay, well your correct images answers that question! Yes to both.
Rick wrote:JaredBanks wrote:hummm??? I didn't actually switch any lines? The black for the siding, or the roofing comes from the material settings. But, maybe you are on to something else
Learn something everyday. I never thought to switch the pens to black and white before going to 3D. !![]()
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 08:23 PM
henein wrote:Command Click, on a Mac, is the keyboard short cut to trim to room. That trims the bottom of the wall to the top of the roof as a default. You can change the way it trims under menu>design> trim to roof. The manual should explain the fine points.
Thanks for all contributions!
/Henrik
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-13 09:42 PM
"Are your materials vectorial hatches set to element pen or custom? Maybe that has something to do with it. And do you typically use black pens? It looks like it from your plan. My drawings are all shades of the rainbow... well a couple shades! "
How do i change pen or custom? And how do you change black pens. I hope I don´t ask to much stupid questions.
When i Try to fit the roof to walls by trim to roof it dosent happen anything if i choose trim top. If i choose trim base the wall will disappear.
/Henrik
