‎2009-08-10
12:57 AM
‎2023-05-23
04:53 PM
Rubia Torres
‎2009-08-13 06:44 PM
‎2009-08-13 07:23 PM
‎2009-08-13 07:53 PM
‎2009-08-13 08:03 PM
‎2009-08-13 08:14 PM
JaredBanks wrote:hummm??? I didn't actually switch any lines? The black for the siding, or the roofing comes from the material settings. But, maybe you are on to something else
Learn something everyday. I never thought to switch the pens to black and white before going to 3D. !
‎2009-08-13 08:16 PM
‎2009-08-13 08:18 PM
‎2009-08-13 08:19 PM
Rick wrote:JaredBanks wrote:hummm??? I didn't actually switch any lines? The black for the siding, or the roofing comes from the material settings. But, maybe you are on to something else
Learn something everyday. I never thought to switch the pens to black and white before going to 3D. !![]()
I always liked the Internal Engine, even though most here seems to go via Artlantis.
‎2009-08-13 08:23 PM
henein wrote:Command Click, on a Mac, is the keyboard short cut to trim to room. That trims the bottom of the wall to the top of the roof as a default. You can change the way it trims under menu>design> trim to roof. The manual should explain the fine points.
Thanks for all contributions!
What do you mean with "command klick"?
/Henrik
‎2009-08-13 09:42 PM
