4hotshoes
How to get Doors and window Simple openings with trim?
The default setting for a simple opening is just a hole in the wall, but I want the same trim as if a door leaf or window sash were removed. I do not see how to make that an option. Any ideas?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
Lingwisyer
Guru
You can select a standard door and select the empty leaf. Not sure if you can do that for a window though...
Ling.
