jc4d
How to grey out UI via GDL
Is there a way to grey out a section in the object's settings window?
Cheers.
1 Solution
Don't script anything in the user interface for that label.
Or if there is a script there just comment out every line.
Go to post
4 Replies 4
jc4d
That was easy, thank you.
If you modify a library part of the default Archicad Library, it is a good idea to first save it under another name and modify that.
jc4d
Thank you for the advice, it is importatn to leave the originals untouched.
