2004-09-20
10:25 PM
2023-05-25
04:38 PM
Rubia Torres
2004-09-23 09:28 AM
2004-09-23 03:18 PM
Dwight wrote:Neat idea Dwight. This could be tip o' the month material.
it takes four holes overlapping - one goes up toward each corner.
To learn the wallhole direction, start changing the code - this kind of vector tuning is easy, try 1,1,1 - should yield a 45 degree angle.
2004-09-23 03:36 PM
2004-09-23 08:54 PM
kliment wrote:It will work if he layer intersection numbers are different - the wall with the window is on a different layer.
Hi, Marin, hope thisl helps you. It's good for use in Plan View though.
2004-09-24 02:45 PM
2004-09-25 02:31 AM
2004-09-25 02:46 AM
2004-09-25 07:46 AM
2004-09-26 02:09 AM
2004-09-26 02:18 AM
