How to make a non-ortho hole in a wall?
MarinRacic
How to resolve this? I need to make the windows cut a non-ortho hole in walls... I had a similar question a few days ago regarding skylights and holes in roofs, but I have absolutely no idea how to work this out!
In 2D I can create a patch, and in 3D I can use SEO to make the kind of hole I need, but for every change I make, the process must be repeated. Is there a way to do this really easy?
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
32 REPLIES 32
MarinRacic
Thanks everyone for your effort and please check the Wishes section as I'll post a poll for this feature to be included in the future updates of AC libraries. We don't have to wait for AC 9.1, 10 or whatever, just a simple update of libraries will do...
Aussie John, I've used your empty window, thanks a lot! However, I'm getting an error message every time I open the 3D window - screenshot is attached. Does the 3D script need adjusting?
AC ...20/21
www.3Dart.hr
Dwight and John, you are right, this is a good way. Thanks for sharing.
I am so much in habit to struggle with wall junctions, that i forget sometime other ways.
I just added hotspots to move the angle graphically. Hope this can help.
Next step could be to make the two sides independant, or edges visibility control. Anyone?
EDIT:
deleted attachment
See rectified object, w_splayed reveal4.gsm.zip
MarinRacic
Way to go people! It's great to see users sharing experiences this way! Thanks everyone for contributing and I'm sure the final window surely deserves to be included in the standard AC library.
AC ...20/21
www.3Dart.hr
Aussie John
ooops
it was sunday and I wanted to go out. Try Oliver's Solution (he is a much better coder than I am). I wanted to put the editable hotspots in too but had already spent too long on it.
Cheers John
[/size]
Nice work, guys!
There was just one small problem - the window didn't inherit the wall contour line pen, so I added a parameter for it. And a preview picture
Hi Kliment, I did not check the script enough, sorry.
There is an automatic way to achieve this. This is rectified.
Good way of working. At the end, i hope we shall have a correct window.
Petros Ioannou
Sorry i can't contribute to this development but my GDL is rusted and don't have a lot of time.
By seeing this common work and cooperation and the will to help someone makes me sure that we have chosen the right application.
No software documentation will ever reach the level of assistance that this forum has reached!
I wanted to say that the best add-on for AC is ArchiCAD-talk.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
MarinRacic
Hell yeah! And it's free!
AC ...20/21
www.3Dart.hr
Dwight
It does help to READ THE ACTUAL DOCUMENTATION FIRST, however.
And, like, maybe you should look at every conceivable dialog box in the system, too.
Most of what we do here is help people remember the things they once knew, but forgot.
Dwight Atkinson
MarinRacic
Read it. Many times.
The forum exists exactly for solving problems like these, don't you agree? I don't remember the chapter in the user manual saying how to make a splayed opening in the wall. Please let me know what's the page number...
AC ...20/21
www.3Dart.hr
